20withascooby Posted October 12, 2007 Posted October 12, 2007 ryt my rear wheels are rubbin need to do sumthing quick my options are roll the arches, skim a bit of the inside of the alloy uprate to sti v5/6 suspension or go for coilovers i got about 400/450 to spend seen sum tein coilovers on fleabay but can any body tell me if they will fit my car and how easy are they to fit and will they do the job of stiffining up my rear end
matthew_buckland Posted October 12, 2007 Posted October 12, 2007 We've had the same problem, needed to firm my rear too (no comments please), We put Yoko's 215,40,17's on the rear and it has stopped a lot of it, (just the skirts that catch now) we also put new shocks on, strangly enough we cant have Yoko's on front as we have to run spacers and they catch the arch.
20withascooby Posted October 12, 2007 Author Posted October 12, 2007 i already have 215/40/17s on there it only does it when go over sevre bumps or when the car is boosting on a corner or sumthing and the weight is all on one side.its catching on the top of the tyre on the side will coilovers stifen it up a bit
matthew_buckland Posted October 12, 2007 Posted October 12, 2007 We fitted a RA suspension to mine last year and it rubbed worse then before, As for coilovers it should help with the body roll and stiffness, as i said we just changed the shocks and its loads better now. Rolling the arches is where basically where they roll the inner lip in, gives you about 8mm more clearance.
20withascooby Posted October 12, 2007 Author Posted October 12, 2007 where can i get this dun and will it def sought the problem or will they only be able to tell after its been dun was looking at these http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...A:IT&ih=015 and ofund sum hks ones
matthew_buckland Posted October 12, 2007 Posted October 12, 2007 I can recommend a good bodyshop but not sure if he will roll arches, i'll ask him.
20withascooby Posted October 12, 2007 Author Posted October 12, 2007 so i need a bodyshop then to do it not a garage.i no off sumbody who myt be able to do it local aswell he dun my front end after i ran over it and boke it into lots of peices
matthew_buckland Posted October 12, 2007 Posted October 12, 2007 so i need a bodyshop then to do it not a garage.i no off sumbody who myt be able to do it local aswell he dun my front end after i ran over it and boke it into lots of peices I take it you mean you run over a splitter not the entire front end of your car cos that would just be silly
20withascooby Posted October 12, 2007 Author Posted October 12, 2007 yep gt caught on sumthing folded under the car and then i ran over it b4 i noticed it was wats the word f***ed.fibregalss it all bk and smotted it into front bumper and re sprayed it all for 200
Jamessti Posted October 12, 2007 Posted October 12, 2007 (edited) If you want to get your arches rolled try this company http://www.archenemy.co.uk/tech.htm . I've not used them myself, I've heard they are quiet good. Edited October 12, 2007 by Jamessti
20withascooby Posted October 13, 2007 Author Posted October 13, 2007 went sumwhere today and was told ven i get the arches rolled it will prob still jsut about catch it so guna get sum skimmed of the wheel so it goeso n a bit more
20withascooby Posted October 14, 2007 Author Posted October 14, 2007 will the suspension on a 95 ra be the same as mine is a aftermarket kit taken off a 95 ra but just wondering bout the holes and fitting and that will it be the same also how do i uploadp ics on here wanna put some up of m ycar now gt few things dun to it
