Suspension Help Plz
help just fitted my wheels they are only 17s but the offset is a little bit different to what i shud have i thought id got away with it because the frnts clears evrything and doesnt rub or catch but the back is a diff story.when i go over bad bumps at over 30 mph they seem to rub on the outside of the tyre.only does it sometimes.i want to buy new suspension for it to make it stiffer so the back doesnt go down so easy.in my opinion it goes down to easy.is the sti suspension any diff i have a 94 wrx import
hi i beleive the sti suspension is a bit stiffer, i fitted tpe ra suspsension to my sport and it made a lot of difference to the ride, but if you want it really stiff then go for some coil overs :D
the ra suspesion is a stiffer ride. i went up to 17" on my RA, it's fine with a passenger in the front but with people in the back it will rub a bit on the back when you put it into a corner. hope this helps :D
