Whiteline Coil Overs?
A lad at work was telling me that he is thinking of buying coiovers for his 05 sti, he mentioned whiteline are bringing out a range, does anyone have further info?
cusco george would be the man to ask
im sure they'll be top quality if they are though
jim
Yea, I read somewhere that Whitelines parent company were producing a new set of coilovers that adjust from the bottom so that theres no chance of the spring shifting when your going over jumps.
Cant remember where I read it but im sure someone in the know will be along to keep us right
Graeme
hi chaps gmd automotive are launching a new range of coil overs for the subaru range,evo,honda and most types of uk spec cars. i have the
first set of gmd kb c/os for the mini, these are some piece of kit. i am fitting them to kevins girlfriends car as a test for gmd. this set will be monitered and will feature in photo shoots for magazines. the mini c/os come on line soon. kevin and i have secured a deal with gmd/whiteline to run the new track -hillclimb scooby, and test all new products that are in the pipeline -suspension-bov valves atomic boost valves,underdrive pully kits, short shift kits and the new high performance brake systems that are in the design stage. the spec of the shockers are as follows1) road type standard castings, dampers uprated ,with springs /handling kit for fast road use with whiteline bars etc
2)road-track coil overs
3)3way c/os with remote resevoirs- soon to be fitted on j3 geo
stainless steel bodies coated with a black finish to repel anything the weather can throw at them.
the c/os consist of
40mm inverted dampers
pure rubber dust seals /not hard plastic
adjustable bump and rebound settings at the turn of a knob
teflon inner and outer dust seals (bet somebody will have some comment about that
anodised lock rings and top mounts
some types also come with adjustable top mounts
and a new way of adjusting ride height (the bottom of the strut adjusts as well as the top(clever the japs
i will post up piccs as soon as i can
this is not an advertising post i am just relaying info to the guys that asked geo :D
Edited by cusco kid
Saw the mini coil overs last night, superb piece of engineering, will see the lad at work and pass on information for his sti. Made a suggestion to the better half about fitting coil overs to the RB, her reply was she prefers the pill, ah well you win some you lose some.
