Removing And Fitting Injectors - Help Needed Please
Hey guys
Having problems removing my injectors.
Ones on passenger side does not look to bad but drivers side I cant even see them or know what to remove to get to them?
Any advice would be great .
Thanks
Edited by Chris.Mcd
Classic or Newage?
15-20 minute job to remove them if its a Classic, a little longer for a Newage.
Russell
On a newage, sorry forgot to mention that.
Its just getting to them on the newage. Alot of stuff in the way of them. Air box, water bottle, battery etc.
Hi there
The passanger side should take you around 45 min if your good with the tools but the drives side is i little more tricky.
You will need to remore the resivoir bottle , airbox (to make it easyer) and the brackets below the res bottle. Once you have done this you should have clear accsess to the injectors( there will more than likely be a few wires in the way so take your time)
When puting your new injectors in , watch the o-rings on the top as thef can be a little tricky(put some oil on them when installing)
Hope this works out for you.
Higgy
give me a ring if you need any help
07740 724 185
Hi there
Higgy
07740 724 185
Thanks very much Higgy ;)
I have removed the Battery, water bottle and bracket from passenger side. Can see the injectors now :D
Drivers side I have removed the airbox. Will go remove the reisvoir bottle, so I can get to remove the bracket.
Thanks for the advice and number.
Will give you a shout if I need any help :D
