chris_c201 Posted August 29, 2007 Posted August 29, 2007 (edited) Guys, Couple of questions on changing my HKS SSQV back to a standard re-circ valve.. the car has an FMIC and i'm slightly thrown by the whole setup.... 1 - Does any one have a pic of a std STi5 DV or can someone tell me whether the bottom or side hole is the input, a pic would be great! (dumb q i know!) 2 -The 2 holes on the DV seem to be 40mm, the hole on the FMIC pipework is 40mm so thats fine, however, the hole that is currently blanked off (the re-circ going back in hole) seems to be 30mm... any idea's how this connects up, do i need a reducer of some sort? TIA Chris Edited August 29, 2007 by chris_c201
johnnyr6 Posted August 30, 2007 Posted August 30, 2007 A standard sti 5 dv is not use as it's bolted onto the intercooler itself, either one from an earlier car or an aftermarket one is what you need.
