woody-cdas Posted July 27, 2007 Posted July 27, 2007 The other morning I went to my car and my window wouldn't work. it just buzzes when you move the switch up or down. It was working perfectly when I parked the car the night before. Anyway I have had the switch apart and cleaned it all but still no good. I don't think there is a problem with the motor but I am not sure how to wire it up to another switch to test it. The thing is it has stopped al the windows from working which is a real pain in the ass. Does anyone have any ideas? I want to try another switch but if it's the motor then I don't want to fork out for a switch. God i really want a new car now. Please HELP!
woody-cdas Posted July 27, 2007 Author Posted July 27, 2007 Aparently there is also a relay - I checked the fuses already. That would ring true as it is buzzing which relays normally do when they go don't they? Does anybody know where this relay is located?
big jay Posted July 27, 2007 Posted July 27, 2007 Have you tried under the dash on the driver's side there's a fuse box there on the side behind the lever for the bonnet,or all the relay's are in the main fuse box under the bonnet.I hope this help's.
woody-cdas Posted July 27, 2007 Author Posted July 27, 2007 Thanks Big Jay - will have a look when I get home tonight
