frank c Posted February 16, 2007 Posted February 16, 2007 As above.. What's the difference with these two items and how do they compare ?? Cheers
micra_wrc Posted February 16, 2007 Posted February 16, 2007 Frank, have a lookie here for a good explanation by the Squirrel
euan_r Posted February 16, 2007 Posted February 16, 2007 same thing frank. see http://en.wikipedia.org/wiki/Blowoff_valve take it you mean vent to air or recirculating. If u want whoosh noises u want a vent to air. gives u pops from the exhaust as well, cause injectors add enough petrol for air thats no longer there. believe this can thin out the engine oil over time though. but if u want whoosh go for it. Or u could be taking about difference between dump valve and turbo bypass valve. beaten to it [:$]
frank c Posted February 16, 2007 Author Posted February 16, 2007 Thanks Imy, A wee bit info overload there lol.. Flame suit at the ready..... but what's the difference between the two ? as i'm thinking about fitting a FMIC and would like to know what's best to fit.. I like the standard one that's fitted already and i'm not a fan of the "big bus psssshhhhhhhhh".. Is it possible to keep and fit the standard one on to the F/mount with some kind of adaptor? Cheers
frank c Posted February 16, 2007 Author Posted February 16, 2007 Cheers Euan, Interesting reading ) Looks like i will be wanting a Recirculating one.. Anyone know if i can get an adaptor for fitting my OE one or what's the best thing to do ?
RS Grant Posted February 16, 2007 Posted February 16, 2007 You'll be wanting a Forge Recirculating one for your FMIC pipework mate, just like me... Group Buy?? lol [] Cheers, Grant
colin_ross Posted February 16, 2007 Posted February 16, 2007 You can get adaptors that will allow you to bolt your d/v onto your new i/c pipework. When I had the same issue I just boust a new d/v that bolted straight on as it was much easier. Have a look on ebay as there normally loads, forge are the best in mu opinion.
frank c Posted February 16, 2007 Author Posted February 16, 2007 Thanks Grant and Playsatan.. Forge it is then )
RS Grant Posted February 16, 2007 Posted February 16, 2007 No bother bud, you've got a reply. [] Cheers, Grant
