david_taylor Posted December 30, 2006 Posted December 30, 2006 My brother in law has a 2000 Bugeye WRX. He just called me to say a amber light lit up on his dash then went off a little while later. He does not know what it is, and is worried. He is still on the road and called to see if I knew, but mine is a classic and a different dash. He said it was just above his petrol gauge, and said it looked like a engine. Dont know if the engine warning lights are diff in the classic and original new age. Can anyone help here, and clear this up? Cheers Dave
paulc555 Posted December 30, 2006 Posted December 30, 2006 Dave........as you know mate my kowledge of the impreza engine is almost as extensive as my knowledge of my Cheryls bedroom....but I can tell you it was the CEL light...why its on is anybodys guess....best advice i can offer is to pop along to Duncan at Hypertech if he is open and get him to pop it on the old computer to tell you whats up?? nearly sure Gav can do this for you also..if you ask nicely!!.... sorry i cant be of any more assitance but I cant be gorgeous and brainy...
david_taylor Posted December 31, 2006 Author Posted December 31, 2006 My knowledge is nearly as bad as yours Paul. lol What does CEL mean. Is this the engine warning light?
paulc555 Posted December 31, 2006 Posted December 31, 2006 sure is mate.......had a problem with mine during the summer when the car sat for a few weeks while I was on hols...came back and the CEL was on..turned out to be dirty Idle control valve...but after a few hundred miles it seemed to cure itself and the light went out...
Alan-G Posted December 31, 2006 Posted December 31, 2006 He just called me to say a amber light lit up on his dash then went off a little while later. Sounds a bit like a glitch to me. Why would it go off though is a bit more concering. A bit like crossed wires to me. A Red oil light springs to mind with a Ford I owned. If it's Red then your too late anyways. PaulC555 I touch goats BTW.
st3ph3n Posted December 31, 2006 Posted December 31, 2006 "Check engine light" Means the ECU detected something a bit iffy and flashed a warning. Get it to somewhere with a select monitor (dealer, specialist) and see if they'll give it a check.
david_taylor Posted December 31, 2006 Author Posted December 31, 2006 Cheers guys He is booking it in for a new decent exhaust at Hypertech next week so I told him to get it plugged in to be safe. Hopefully its just a dodgy sensor or something.
micra_wrc Posted January 2, 2007 Posted January 2, 2007 .... sorry i cant be of any more assitance but I cant be gorgeous and brainy... PMSL the Irish are a funny lot i tell ye
diffbuster Posted January 2, 2007 Posted January 2, 2007 Welcome to Subaru Impreza Drivers Club Forums Sign in | Join | Help Search Subaru Impreza Drivers Club Forums SIDC Home | SIDC FAQ | SIDC Shop Forums Subaru Impreza Drivers Club Fo... » Regional Areas » Scottish Scoobies » Re: Engine Warning Light Re: Engine Warning Light 02 Dec 2006, 20:16 diffbuster Joined on 23 May 2006 Posts 52 Re: Engine Warning Light Reply Quote The ECU can diagnose any fault that may arise due to abnormal signals that are sent to the controller. The ECU Check Engine Light (CEL) will illuminate in the instrument console if there is a problem with any of the computers inputs. It is possible to find which sensor is faulty by following these steps: · Turn ignition OFF. · Connect read memory connectors. These are the small black connectors under the steering column above the pedals. · Turn ignition key to the ON position (Engine OFF) · Engine Check Light turns on · Code is indicated by Pulsing light - See below · If Code is OK Turn ignition OFF disconnect the black connectors · If CEL returns a number of different pulsing lights then check the ECU code table. · Turn ignition to the OFF position. Disconnect the black connectors. · If there is a fault, then check the appropriate sensor. The ECU codes are displayed as pulses of the CEL. If CEL goes out there is no fault. In Diagnostic Mode – No Fault is indicated by the CEL continuously & evenly flashing on/off (this is also used to indicate the successful completion of an ECU Reset) SEE "OK code" in diagram below. The long pulses (1.3 Seconds) indicate Tens and the short pulses (0.2 Seconds) indicate ones. Pulses are separated by Short Pauses (0.2 Seconds), multiple codes are separated by a Long Pause (1.8 Seconds) SEE "Trouble codes" in diagram & examples below. The simplest way for an inexperienced mechanic to retrieve codes is to write the codes down in a sort of Morse Code (dots and dashes), and start a new line when you get a 1.8 Second pause (for NEW code), and then add the actual numbers up after code retrieval is completed. must be starting to get the hang of this computer lark. Code ITEM 11 Crankshaft position sensor 12 Starter switch 13 Camshaft position sensor 21 Engine coolant temperature sensor 22 Knock sensor 23 Mass air flow sensor 24 Idle air control solenoid 31 Throttle position sensor 32 Oxygen sensor 33 Vehicle speed sensor 2 35 Purge control solenoid valve 42 Idle switch 44 Wastegate control solenoid valve 45 Pressure sensor – Pressure exchange solenoid valve 51 Neutral position switch -------------------------------------------------------------------------------- Report Report abuse View Complete Thread Copyright © The Subaru Impreza Drivers' Club. All Rights Reserved. You are reminded that your use of these forums constitutes your acceptance of our Services Agreement.
diffbuster Posted January 2, 2007 Posted January 2, 2007 didnt post like it was meant to but the info is there.
imprezapete Posted January 2, 2007 Posted January 2, 2007 I'm putting a Tenner bet on camshaft position sensor Had mine done already, it just flicks CEL on now and then. Got Chris Alan in east linton to plug in his ECU checking handheld. £150 all in when I had it done.
