the squiggle Posted January 19, 2006 Posted January 19, 2006 3 guys from local kebab shop build a quick Scoob Do not know if it beats AndyF but it must be close Grant
st3ph3n Posted January 19, 2006 Posted January 19, 2006 So what's that configuration called then? FME - front mounted EVERYTHING?
the squiggle Posted January 19, 2006 Author Posted January 19, 2006 Defo done in a drag stylee No intercooler as such but a massive Charge cooler similer to the one used on the Focus RS and old Legacy See the exh pipe, external wastegate and the dual plenum chambers, very tasty indeed Very functional interior with a guage for everything Grant
st3ph3n Posted January 19, 2006 Posted January 19, 2006 Things I think I know. Chargecooler - check. Wastegate - check. External wastegate - also check. BUT - I know you've not mentioned it there, but what is a screamer pipe in relation to this? Plenum chambers - a bit vage on them. Grant if you'd be so kind to impart some knowledge this way.
the squiggle Posted January 19, 2006 Author Posted January 19, 2006 Plenum chamber is the two big silver boxes either side of the engine and the charge cooler is the silver one in the middle Will explain better tomorrow if required as i need to hit the hay for work tomorrow Grant
the squiggle Posted January 19, 2006 Author Posted January 19, 2006 Screamer pipe is the narrower guage pipe than runs under the main exhaust pipe from the external wastegate That would be one loud exhaust at full pelt, similar to the side exit i used to have but way more stylish then mine Grant
ed-209 Posted January 19, 2006 Posted January 19, 2006 very tasty. should be called opal fruits, made to make your mouth water. I wonder if there kebabs are any good also. Ed
ally-b Posted January 19, 2006 Posted January 19, 2006 'Sheesh' ! He's no 'donnering' aboot What is their home-delivery number ? Yer kebab would arrive before you put the phone down Al.
RS Grant Posted January 19, 2006 Posted January 19, 2006 I had a Screamer Pipe on the GT4... and its pretty crazy, hopefully you'll be able to hear it at the Rolling Road day as I think the new owner is sticking the Castrol Rascal on. Possibly finished and running high boost!! Cheers, Grant
GrantyBoy Posted January 19, 2006 Posted January 19, 2006 I'll be giving him a kick up the arse to make sure its done in time. Think he's just bought a load of silicon hoses for the engine in preperation of BIG BOOST
RS Grant Posted January 19, 2006 Posted January 19, 2006 Haha, good good Grant.... Its been built with the aim to run 1.8bar and a rev limit of at least 8k with the uprated rods, so tell him not to be shy when he gets it mapped!! Cheers, Grant
