paulc555 Posted December 18, 2005 Posted December 18, 2005 Waiting on some information coming through from Martin UK300...thanks mate... in the meantime while i have the air intake of can anyone advise how to change the indicator bulb in prodrive uk300 style lights....i cant get my hand in to twist the bulb holder free..any tips???? and highly detailed instructions for a numptie appreciated.... or does anyone know anywhere that can do this for me as i've just had a manicure..... no its just im thick really... cheers
jamie_wood Posted December 18, 2005 Posted December 18, 2005 Paddy, Just pull the headlamp uniy out. It takes about 10 seconds for a trained monkey to do, so you should manage it by tonight. Remove the grill bitty, then the two bolts behind there (10mm socket needed) then remove the one next to the wing (also 10mm) and hey presto.....access. P.s you will need to pull the unit straight forward to get it to pop out of the little socket it sits into. Dont be rough though If you need any more help....dont call
paulc555 Posted December 18, 2005 Author Posted December 18, 2005 mmmmmm will give it a go....... but its raining now...so cant go our will ruin my hair.... thanks for the kind comments ......
paulc555 Posted December 18, 2005 Author Posted December 18, 2005 grill bitty.....behind where???? i thought you were technical......
