mikeyjm26 Posted December 16, 2005 Posted December 16, 2005 Hi guys, put the car in for an MOT and it failed on emissions, told the guy to replace the centre section that I have with it and he is asking me for the original backbox as well. Is he right? Surely I don't need that to pass the emissions test, really don;t want to have to fork out a couple of hundred quid on that. Thanks Mikey
craig mac Posted December 16, 2005 Posted December 16, 2005 No you dont The centre section should have the cat in it. Back box has nothing to do with MOT's unless holed etc Craig
Johnny50 Posted December 16, 2005 Posted December 16, 2005 The Nur Spec R is a 3 inch system, and also replaced the centre cat, so your standard centre wont fit onto the backbox. So he is right. Also....can you get in touch with me...been trying to call you.
colinj Posted December 16, 2005 Posted December 16, 2005 As said the Blitz Nur spec R ir 3" bore while standard system is 2.5", you will need both center & back box to swap over. Does it still have the front cat downpipe in place?? Surely it would pass with that & maybe be less hassle to switch??
