boost problems
My 2000 turbo full decat tek2 exchange ecu .I am having problems with boost ie 3 4 5 it goes to 20 psi fluctuates .I have to clean out valve on drivers near air box plus pipe work this cures for a time .Then it comes back should i stick on dawes to cure this . I dont know how accurate boost gauge is with 20psi on tdo4 ? an ideas please
how much oil is on the dipstick if is above the dot or as much as the notch it is 2 much oil.
i had the same proble with my 97 wagon but the oil was 1 of the problems.
ps check oli when cold.
wullie
Just had car serviced at awd oil levels on the right mark .jcscoob already have a dawes it was on before ecutek and i took it of .Hows the car doing jcscoob because i see paddy and davie are at dalgety bay this saturday.I will try the dawes back on an see how it goes
