re: engine oil
Recently bought an 95 scoobie wrx import.....and am looking to service it....which engine oil is recommended....nearest performance outlet recommended millers 10-60..... any help would be appreciated....cheers
Miller 10 60 is great for the older cars, the thermal dynamic qualities of it are very good also, ie it will assist more with the cooling of the car as well. Because it is a top notch oil you can leave it for 4000miles between changes as opposed to 3000, I use it when I can get itface-icon-small-wink.gif
Callum W
Smell of petrol in the old oil is not that good but you are doing the right thing by changing the oil.
Does the car have a Aftermarket dump valve, if so this could be your cause. You could also be over fuelling dramatically, best to get it checked out.
Grant
