FS, New age Sti parts
Sti7 PPP kit. Gems daughter board, Sports cat DP, and complete Prodrive exhaust system. The exhaust from the DP back has only done
+/- 200 miles from new. Kit will not include the up rated fuel pump or the restrictor valve.
Also for separate sale, straight through exhaust system from DP back to a rear genuine polished Sti titanium back box. (Imported from Japan) This is one of the finest sounding exhaust systems for any new age Sti and I hate having to remove it more that words can explain. However, I need to upgrade to a 3? exhaust system front to back.
Standard Sti headers c/w up pipe.
All parts ready at the end of Jan.
Also time for a clear out;
New age tow bar assy, c/w the removable swan neck tow bar. With swan neck removed the tow bar frame is not noticeable on the car at all. Used for towing Westfield on A-frame (less than 500 KG).
Standard fit double din stereo unit if anyone needs it to perhaps upgrade. (Had to move the Secs system down to fit gauges on a dash pod)
New age genuine Subaru dash mount pod, which the Secs 1004 came supplied in from Power-Station. Open "letter box" at front, but I could supply with a carbon fibre rectangle sheet for the front ready for cutting to fit gauges or other if required.
Sti7 front head lights.
Sti7 standard anti roll bar and drop links.
Sti7 standard brake hose's.
Sti7 standard springs.
Think that's it for now.
Iain,
yes the headlights would fit, but it's not a direct swap, as there's some electrical work to be done. I think your headlights have one conector for the headlamp adjustment, and the STi ones have two. Nothing too difficult for an auto electrician, but it's not a straight forward plug and play replacement.
Jools may be able to offer more info, as the headlamps he has just now (Prodrive UK300 ones) were designed for the standard bug-eye model.
John
<< Thanks for the help above lads, but afraid the lights are provisionally sold. >>
Ok thanks anyway. Let me know if the sale falls through.
Iain
Additional info on the PPP kit to assist as I have received so many questions.
Note; This PPP kit is for a MY02 Sti Type UK Impreza, nothing else. That comes from Mike Wood at Prodrive, so I?m sure that info is factual.
The PPP kit is still for sale, but there are lots of people who want various bits and pieces. I need £750 for the kit, which costs £2000 new. I had it fitted just over two years ago to my MY02 Type UK Sti.
You would need to get it fitted by someone who knows what they are doing. A Subaru garage would know their way around, as would lots of tuning companies that Scooby people use. When upgrading to more power the first thing you need is the sports free flowing down pipe and these cost over 600 quid, so 750 plus a few more bits you will need is a good buy. You could go cat free if you wish, which would be cheaper.
What I have for sale is as follows.
1 x ?Gems? daughter board. This is regarded as a ?piggyback? system as it fits over the standard ECU on the car and requires soldering in place. The details on the Gems board are as follows;
Sti Subaru 62 (the six might be a zero...02)
G 1.47/02
X1075
1 x Prodrive Sports Cat down pipe.
1 x Prodrive mid section SS exhaust section with small box.
1 x Prodrive SS back box
2 x parts of the kit you will need are a tiny restrictor fitted to control boost spikes and an up rated fuel pump. The fuel pump you can get off SN for 100 quid and the restrictor valve from Subura for a few pounds. These parts I am not selling as they are needed for my next upgrade project.
This is the very first PPP kits Prodrive did produce for the new shape Type UK Sti?s. When fitted on my car, it produced 301 BHP on the rollers. Since then PPP kits are a remapping of the ECU, where as this one tricks the ECU in to producing more boost.
I hope that helps a little. I now intend to go back through all the PM?s I have received on SN & SIDC and inform people that I will break the kit up, as potentially I believe I have buyers for all the bits.
Jools
Jools,
F'like mannie face-icon-small-smile.gif - happy new year face-icon-small-smile.gif
I'm after the tow bar assy if it's still up for grabs.
Drop me a line to let me know what you're after for it.
Cheers,
Hey N.
Canna moanface-icon-small-smile.gif Happy NY 2 u 2 face-icon-small-happy.gif
Tow bar is yours...and I'll help fit the thing too. Will drop you a mail soon as I get a minute.
Got to go for now...
