wrx kenny Posted August 13, 2009 Posted August 13, 2009 had the car hooked up to see why engine management light was coming apart from picking up fault also showed car was running lean . not being much of a mechanic what would be the usual reasons for a car to run lean ,only mods are typhoon induction kit apart from that standard . help as desperate to put all the toys on gathering up in garage so i can get it across to andy f but need to get initial issues dealt wae first thanks kenny
nkwrx Posted August 13, 2009 Posted August 13, 2009 Induction kit will be the reason I would think. Air/ fuel mixture ? More air now less fuel. Am sure I'll be corrected if I'm wrong tho
P1_Paul Posted August 13, 2009 Posted August 13, 2009 Correct, if the induction is changed then 9/10 it needs rescaled.
thewelsho Posted August 13, 2009 Posted August 13, 2009 Induction kit will be the reason I would think. Air/ fuel mixture ? More air now less fuel.Am sure I'll be corrected if I'm wrong tho Woulda been my guess, but like Kenny Bhoy, I'm not mechanically minded either
green_goblin Posted August 14, 2009 Posted August 14, 2009 (edited) I would have thought putting an air filter on wouldnt have really made you run lean as your maf sensor tells your ecu how much air flow its getting and it should therefore plonk in enough fuel......but hey im prob wrong!! lol If it was me i would throw on all the goodies then drive it really easy up to andy for a map! Jase Edited August 14, 2009 by green_goblin
stuarted Posted August 14, 2009 Posted August 14, 2009 if it's not been mapped an induction kit will make it run lean, some more than others. Stay off boost till it's been mapped
scoobysailor Posted August 14, 2009 Posted August 14, 2009 I hope it's as simple as a remap for you Kenny - You know the snags I had with mine recently........knackered MAF,fuel pump, filter etc. Might be worth speaking to Dunc up at Hypertech....... You don't want to get all your goodies fitted, go for a mapping and not be able to get it done.
